Alignment after lowering. Camber kit?
Posted: August 5th, 2004, 9:02 pm
by Tyler17rose
I'm installing B&G springs with ZX2-R struts this weekend hopfully. And i'm gona get a camber kit and get it alligned.
For you that have lowered their car. Do i need to get both front and rear camber kits? OR is it really only neccesary for the front?
Re: Alignment after lowering. Camber kit?
Posted: August 6th, 2004, 10:31 am
by jpwmx3
You don't necessarily need both front and back, but it makes it easier to re-align with both, should you run into any problems with alignment.
Posted: August 6th, 2004, 10:48 am
by mx3optidrive
Every car is a little different. I got mine done and I got both front and back, but I didn't need both. I am just keeping the other one in case I do something else to the suspension and end up needing the other one, just in case. It doesn't hurt to get them both.
Posted: August 6th, 2004, 1:12 pm
by JWMX3
thats right,, every car is a little different... I DID need adjustment on both front and back... but camber isnt a big problem anyways, its the toe-in you get when its lowered but the alignment will take care of that
