I'm installing B&G springs with ZX2-R struts this weekend hopfully. And i'm gona get a camber kit and get it alligned.
For you that have lowered their car. Do i need to get both front and rear camber kits? OR is it really only neccesary for the front?
Alignment after lowering. Camber kit?
Mods:
- jpwmx3
Re: Alignment after lowering. Camber kit?
You don't necessarily need both front and back, but it makes it easier to re-align with both, should you run into any problems with alignment.
1993 GS V6/402,000km http://images.cardomain.com/member_imag ... 290_18.jpg
Every car is a little different. I got mine done and I got both front and back, but I didn't need both. I am just keeping the other one in case I do something else to the suspension and end up needing the other one, just in case. It doesn't hurt to get them both.
- JWMX3
thats right,, every car is a little different... I DID need adjustment on both front and back... but camber isnt a big problem anyways, its the toe-in you get when its lowered but the alignment will take care of thatEvery car is a little different. I got mine done and I got both front and back, but I didn't need both.
