smoothest ride?
ClutchedMX
smoothest ride?
i was lookin at H&R lowers and a ZX2 strut set up... i was wondering if this is the better way to go if your looking to reduce bumps and small imperfections in the road.
- atlantamx3
Re: smoothest ride?
If you lower your car with stiffer sptrings an struts-- you will INCREASE the tiny bumps & imperfections that you feel in the road.
GuidoBiRiChiNo
Re: smoothest ride?
ZX2+eibach
Be sure is the smoothest possible is you wanna lower it.
-italian lonely MX'er-
ClutchedMX
Re: smoothest ride?
ok thanks...so ZX2 struts will make the ride even less smooth?? what would you suggest then.
GuidoBiRiChiNo
Re: smoothest ride?
Probably it can be an idiot answer but... the smoothest ride of all is the stock one. Of course.
ClutchedMX
Re: smoothest ride?
you cant make the ride smoother?
ProtegeSTS
