i drove into a big pothole, bottoming out my car REALLY hard. ever since then when im driving my front drivers side tire makes a rattling sound...kinda like if i had a loose lug nut. also, when the car is off the ground i can grab the wheel at the top (or bottom) and it will kind of move in and out, as if making a slight adjustment in camber. my wheel/caliper/hub everything moves together.
so i know that the rattling sound is my wheel slightly wobbling back and forth...but what the heck could be causing this? did i bend something? blow out a bushing?
blown bushing?
ProtegeSTS
Re: blown bushing?
wheel bearing
or could be the strut to knuckle bolts... get under there and start trying to tigten stuff...see what's loose.
-93 MR2
#129 E-stock
#129 E-stock
Re: blown bushing?
so you definately think its something loose...and not something broken?
i dont notice any difference at all in the handling feel, just the noise coming from the vibrating wheel hub
ProtegeSTS
