zx2 related parts
RayRay
zx2 related parts
Post by RayRay »
Okay I have my H&R springs and now I'm about to order the zx2 struts. I did LOTS of searching and PM'ing to get things checked out. Now I just want to do one last check before I go ahead and order everything.<p>Here's whats on my list:<p>- (4) zx2 struts (duh) from oemfordparts.com
- (2) zx2 front strut perches from oemfordparts.com
- (2) zx2 front upper strut bearings from oemfordparts.com
- (4) universal strut boots from pepboys (or where ever)
- (4) camber bolts (part #81250) from either
http://www.specprod.com/PROD_DIR/PROD_PASSCAR.html
or
http://www.spcperformance.com/PerfAppsSect/PerfApps_Mazda.html<p>Thats what I got on my list so far. Would I really need the top shaft nuts?
2005 Nissan 350z
1990 Mustang GT - [sold]
1992 Mx-3 GS - [sold]
Falstaff
Re: zx2 related parts
Post by Falstaff »
looks like you have everything - though you may not need to buy the spring perches for the front. the modification of the front perches from a slotted to full circle is easy with a drill/dremel and a vice. it takes a bit of time and patience to go slowly and check your circle to the diameter of the thrust bearing fitting - something you'll want to do often.<p>it'll save you enough money to buy a drill or dremel tool if you don't have one - mroe useful than new perches.<p>don't forget some rust paint to re-paint any grinding you've done or any rusty and esposed metal bits you may discover.<p>glueing hose or rubber over the lower spring coils will stop clinking and clunking you might hear if you don't - my stock springs had a bit of stock covering but we added some clear hose to other exposed areas and i hear none of the noises others have complained about (i have intrax springs with the zx2 struts)<p>wire brush all your screws and bolts before you reuse them and they should be fine - i reused all of my top nuts - they were in good shape after a bit of cleaning<p>only other thing i had to do was adapt the bumpstops from my stock dustboots to work with the dust boot covers ( i bought the expensive zx2 ones - not really necessary to get those because i still had to adapt my bumpstops after i cut them the recommended amount in the intrax guide that came with my springs).<p>hope this helps - pm me if you have any questions
Mradio
Post by Mradio »
Looks like you got everything. Good luck with the install.
Btw, could you take some before and after pics?
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Mradio
Post by Mradio »
and my zx2 struts came with top shaft nuts...
