zx-2 vs. mx-3 spring perches
Posted: March 31st, 2003, 12:28 pm
by Redhouse
if you choose not to modify the existing mx-3 spring perches to fit the round zx2 thrust bearing, can you purchase/use the zx2 perches instead? i have heard the are a bit $$ but they would still be cheaper than buying a dremel or stone sander..<p>just curious
Re: zx-2 vs. mx-3 spring perches
Posted: March 31st, 2003, 1:04 pm
by Mradio
if you can find a used ones from zx2, that will be cheaper. Instead of a dremel tool, I used my electric drill, and just bought some dremel stones that can be used like a drill bit. It was only $5.
So I think it's cheaper to modify, unless you can get free zx2 perches from somewhere.
Posted: March 31st, 2003, 1:29 pm
by zytariuk
Just dermel it. I got my spring perches at the local wreckers, but it's not worth the hassle.
