zx-2 vs. mx-3 spring perches
if you choose not to modify the existing mx-3 spring perches to fit the round zx2 thrust bearing, can you purchase/use the zx2 perches instead? i have heard the are a bit $$ but they would still be cheaper than buying a dremel or stone sander..<p>just curious
1996 Black GS 1.8l w. PRM intake and custom exhaust, zx2 strut conversion and Intrax springs, B&M short shifter and SRD bronzoil bushings, Ractive front and rear strut bars, Raxles axles, ESpec clear markers and front signals w. driving lights, Alpine headunit with 10" JL sub, jbl amp and front speakers.
Awaiting installation: Magnecore 8.5 Comp. ignition wires, ACT Stage 1 clutch w. SS clutch line, Outlaw phenolic spacers.
Re: zx-2 vs. mx-3 spring perches
if you can find a used ones from zx2, that will be cheaper. Instead of a dremel tool, I used my electric drill, and just bought some dremel stones that can be used like a drill bit. It was only $5.
So I think it's cheaper to modify, unless you can get free zx2 perches from somewhere.
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Just dermel it. I got my spring perches at the local wreckers, but it's not worth the hassle.
