Where to purchase ZX2 struts (IN CANADA)?
zytariuk
Post by zytariuk »
UPDATE: I took Talon_66's advise :p . Thanks bud!!<p>[ February 01, 2003: Message edited by: zytariuk ]</p>
Talon_66
Re: Where to purchase ZX2 struts (IN CANADA)?
Post by Talon_66 »
Have u tried any of ur local Ford dealerships? I am sure they would be able to give u a clue, maybe Napa, or Lordco also..
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
MrMX3
Post by MrMX3 »
I checked with the local ford dealership here. $93 canadian each.
Mike
1993 MX-3 GS
2.5l KL-ZE
My Cardomain Page
therealstasman
Post by therealstasman »
Last edited by therealstasman on February 17th, 2009, 11:18 am, edited 1 time in total.
zytariuk
Post by zytariuk »
No. It's exactly C$290.72 for the ZX2 struts, plus C$25.00 to have them shipped from Windsor,ON to Barrie, ON. TOTAL C$315.72. Plus, you will need TWO upper thrust bearings. They are C$29.87 each! Now your going to want FRONT boots to protect your struts. If you get the boots designed for the ZX2 struts (like i did) they are C$23.82 each! FInally you need a pair of REAR boots to protect your rear struts. Again, if you get the boots deigned for the ZX2 struts (like i did) they are C$11.38 each, so C$22.76 for both.<p>GRAND TOTAL: $512.76 (CANDIAN CURRENCY). That's $335.37 (US CURRENCY).<p>** If your going to do the ZX2 converstion, do it right and don't try and save a couple bucks. Though i did with the front spring pearches :o , i just could not justify spending something like C$80.00 for each one...when you can just dremel it or ripp it off another ZX2 from a junkyard.<p>P.S: For all you Americans down there! For us canadians to buy virtually anything from the states online, it ALWAYS seems to end up costing us the same amount (usually more) after all these charges and currency converstions come into effect.<p>If you live in the ontario area, contact Barrie Ford (705)737-0447. They will hook you up with no problem at all. Just give them the part numbers i have listed at http://www.mx-3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=36&t=000001 and they will set you up.<p>[ February 01, 2003: Message edited by: zytariuk ]</p>
