tires
tires
Doesn't smaller rims or tires make you go faster than you normally would? Cause I need to get my speedometer calibrated and wanted to know.
Re: tires
same question here i got 60's instead of 65's so does that mean i go alil slower than the speed says?(185/60/r14)
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
- millionflame
Re: tires
It depends on the overall diametre difference between your old wheels/tires and the new ones.<p>Go here to find the speed difference.<p>Tire Size Calculator<p>~A
~ Millionflame (94 GS 120K)
Re: tires
smaller overall diameter = more revoultions per distance = indicates higher on speedo<p>Youre doing 75, it shows 78<p>taller overall diameter = fewer revolutions per distance, = indicates lower on speedo<p>Youre doing 75, it shows 72
-93 MR2
#129 E-stock
#129 E-stock
