sway bars GS and RS is there any difference
- David Witherow
i might be mistaken but is there any difference at all between the GS sway bars and the RS sway bars...........i heard that the GS were bigger than the RS if so i know where i can get some cheep............
Re: sway bars GS and RS is there any difference
You might want to look in the online shop manual under specifications.
