Shaky steering wheel/brakes
Aight I will admit that I know jack about struts/disc brakes. My steering wheel shakes bad at 50mph+. As for brakes I have done about 40 pairs of drums. Are discs easier? Thanks all.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: Shaky steering wheel/brakes
rotors are probably warped. i dont know if its easier but its about the same. pretty direct install and removal. if u know how to do drums im sure figuring out how to do discs arent hard.
here is a site you can check out might help if you want to do a minor upgrade in rotor thickness
http://www.mongrelms.homestead.com/gtxbrakes.html
the wheels are unbalanced. One of the little weights probably popped off at some point.<p>Brakes on these cars is not hard.
-93 MR2
#129 E-stock
#129 E-stock
