Anyone know specs for '92 alignment?
Posted: October 10th, 2002, 2:51 pm
by tk1138
I've taken my car to two different places for alignment (the last was after installing camber bolts). The write ups I got had significantly different specifications for the toe in:<P>Front:<BR>GY: 0.00",0.15" BP: 0.00-0.30(the mark inidcates degrees, not seconds)<BR>The rear is similar in that one uses seconds, and the other uses degrees. The other specifications were in degrees for both places.<P>Anyway if you've got access to the specs for '92-'94, I would greatly appreciate a post of the alignment specifications<P>Thanks
Re: Anyone know specs for '92 alignment?
Posted: October 10th, 2002, 4:02 pm
by ProtegeSTS
not seconds.....inches....just tell them to zero the the toe
Posted: October 10th, 2002, 4:19 pm
by tk1138
Oh! Thanks, now the numbers make sense. (friggin people mixing units...Mars orbiter...,friggin scientists using the same simbols for different things...,friggin non metric systems...)
