Anyone know specs for '92 alignment?
tk1138
Post by tk1138 »
I've taken my car to two different places for alignment (the last was after installing camber bolts). The write ups I got had significantly different specifications for the toe in:<P>Front:<BR>GY: 0.00",0.15" BP: 0.00-0.30(the mark inidcates degrees, not seconds)<BR>The rear is similar in that one uses seconds, and the other uses degrees. The other specifications were in degrees for both places.<P>Anyway if you've got access to the specs for '92-'94, I would greatly appreciate a post of the alignment specifications<P>Thanks
tk1138<P>There's not really anything I want to say over and over.
ProtegeSTS
Re: Anyone know specs for '92 alignment?
Post by ProtegeSTS »
not seconds.....inches....just tell them to zero the the toe
-93 MR2
#129 E-stock
tk1138
Post by tk1138 »
Oh! Thanks, now the numbers make sense. (friggin people mixing units...Mars orbiter...,friggin scientists using the same simbols for different things...,friggin non metric systems...)
