Galant VR4 big front brake upgrade how to
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR><I>Originally posted by presso3 </I><BR><B>the galant VR4 twin turbo ( or LANCER EVOLUTION IV) front brake almost fit your probe , mx6 & my mx3.just a little mod :<BR>1. drill the disc centre hole from 69mm to 72mm(probe size)<BR>2. shave the knuckle caliper mount fit offset (few mm)<BR>3. file the knuckle caliper mount hole fit the caliper (about 1mm)<BR> go to mechanical shop,i think not expensive.<P>the VR4 front disc is 294mm ,24mm thick,2 piston caliper,can fit some 15" rim.<P>if you have a mx3 ,you must buy a pair of 1995-1998 j-spec 2000cc (kfze) astina front knuckle include 5 bolt hub,and change your 4 bolt rim to 5 bolt rim. because mx3 disc centre hole is 55mm only and caliper mount size is too small </B><HR></BLOCKQUOTE>
David Coleman
Re: Galant VR4 big front brake upgrade how to
Good to know, this is something that the 323 guys have been doing for quite some time...never even thought we could apply it.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
- millionflame
Finally! I've been wating to find this out for a long time. Thanks a lot!!
~ Millionflame (94 GS 120K)
i think the kfze astina struts may be fit ours,JIC have the true coilover for it,i'll test it later
92 yellow mtx klze presso,K&N cone filter,KLZE ecu & intake manifold,whiteline front & rear strut bar, apex spring,koni strut,whiteline camber bolt,WHITELINE rear 22mm swaybar,magnecor 8.5mm sparkwire,2.5" custom catback,custom testpipe,FSE fpr,sard oil gas tank,apexi S-AFC,15"RAYS TE37 rim,FALKEN ST-115 tire,EVO4 front brake,mazdaspeed seat,mazdaspeed steering wheel,mazdaspeed front nose
