ABS BRAKES SUCK
ABS BRAKES SUCK
yeah so im in need of nice shocks + springs i was lookin into ground control coil overs but they dont work with abs ... i've also heard you can zip tie the abs line the the shock, but couldn't the abs lock up then... im confused please help
pelado
Re: ABS BRAKES SUCK
It's only the sensor wire, not the sensor itself so go ahead with the zip ties.
