shocks and struts
shocks and struts
i have a 92 mx3 gs.. i am looking for shocks and struts ... i have abs breaks ,which i've noticed excludes me from tokico and also ground control...please help
Re: shocks and struts
Suspension Techniques springs (1.3" drop)
Life moves pretty fast, if you don't stop and look around once in a while - you could miss it.
ya now what is a descent brand of struts that will work with the abs..?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mx3demon:<BR><STRONG>ya now what is a descent brand of struts that will work with the abs..?</STRONG><HR></BLOCKQUOTE><P>Lots of post about this. You're just going to have to find a way to attach the bracket for the ABS wire to your strut. That's the only diff between with & without ABS.
i have no clue how that would be done... any tips or pages that may help
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mx3demon:<BR><STRONG>i have no clue how that would be done... any tips or pages that may help</STRONG><HR></BLOCKQUOTE><P>Tip 1: Look in the online shop manual, the only difference is in a small bracket that holds the ABS wire.<P>Tip 2: Look at your present strut for the same thing. See how complicated it is?<P>Tip 3: Buy your struts. Remove your old struts. Drill a hole in the new strut that matches the old strut. Install bracket and new strut. Enjoy the ride!
thanks for the help ppl........im a dumbass [img]shrug.gif"%20border="0[/img]
