sway bar end links
maldo
sway bar end links
Post by maldo »
Will the end links from the '90-95 Protege fit on the MX-3 chassis?
sneed
Re: sway bar end links
Post by sneed »
i think so if not just make them fit mesure them and get them rewelded should not cost more then 20$
ProtegeSTS
Post by ProtegeSTS »
no, the 90-94 BG chassis proteges have totally different endlinks, and you cannot have them welded to work...<P>one look at the bottom of both, and you'll see why.
-93 MR2
#129 E-stock
