Is there anyway to fix this/ reduce it without buying a new caliper? My rear right caliper is leaking mad and I don't have the funds right now to replace it. <BR>Help please <BR>P.S. this really sucks cause I just put my car back on the road!
Where's it leaking from?<P>You'll probably have to buy a loaded one from your local parts place....they arent THAT expensive, but i hear ya on the no money thing
Where is it leaking from ? the piston or the connection with the line or is it cracked?<P>if it is the piston or the line u might be able to do something if the caliper is cracked or deformed forget about it.<P>anyway since it is a safety equipment don't<BR>attempt anything unless u realy know what u are doing. and be very carefull.
