rear disk brakes
pDhMiBsh
rear disk brakes
Post by pDhMiBsh »
i was wondering if anyone could give me a site or tell me what all i would need to put rear disk brakes on my mx3 thanks
www.krazykustomz.com 1994 Blaze Red V6 2.5 in the works, 1995 eclipse gsx (winter beater haha)
pelado
Re: rear disk brakes
Post by pelado »
You could check out the online shop manual on <A HREF="http://www.mx-3.com." TARGET=_blank>www.mx-3.com.</A>
OsoSlo z28
Post by OsoSlo z28 »
from <A HREF="http://members.attcanada.ca/~dragon64/" TARGET=_blank>vaughn's site:</A><BR>Rear Disc Brakes:<P>It would be possible to swap to the disc brake from a GS in place of the drums on RS. You will need the complete rear spindle assembly, wheel bearing assembly, rear calipers, rotors, flexible brake lines and park brake cable. In addition you will also need the bigger bore master brake cylinder and front because four wheel disc brakes requires more fluid pressure and volume to operate rear calipers than it does to operate drum brakes. Unless you are racing on a tight circuit course where you are on the brakes often there is little advantage to swapping to discs. The disc brake assembly add a lot of additional unsprung weight and do require much more maintenance as the park brake actuator level has a tendency to stick in the engaged position.<p>[ April 08, 2002: Message edited by: cre8v mx3 ]
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
