Tokico Struts
Tokico Struts
Wow you guys on this board know your stuff. Anyhow I was advised that it is best, that when lowering your car you also replace your struts with performance struts, CORRECT?? so I decided to go with Tokico, the price I was quoted was $145 ea. is this good, In Can.$<P>Thanx
ANDREW*<BR>1996 Mazda MX-3 GS
Re: Tokico Struts
What springs are you going to be using them with? The Tokico blues really arent too great if youre lowering more than 1.5" and their factory warranty goes byebye after that same point. They are a pretty good strut for use with Eibach or Suspension Techniques springs though.<P>As far as price, check out <A HREF="http://www.shox.com" TARGET=_blank>www.shox.com</A> as they usually have good prices, although they are in the USA.
-93 MR2
#129 E-stock
#129 E-stock
Re: Tokico Struts
Thanx, actually I was going to use APEX or Suspension techniques, I don't want a huge drop, 1.5" the most.....<BR>Thanx
Re: Tokico Struts
then youre good to go.<P>Of the 2 mentioned, i would go with the Suspension Techniques springs, only because they are a slightly better known company IMO, and i have never heard or expirienced problems with any of their products. That.....and they are a great bang for the buck deal, especially if you still want a good ride....good luck
-93 MR2
#129 E-stock
#129 E-stock
Re: Tokico Struts
Thanx Protege STS, I am glad that there is someone with your kind of knowledge on this board because suspension to me is the second most important part of a car, and most people don't know a whole lot about it...<P>Thanx again (I probably will go with Sus.T.)
Re: Tokico Struts
What shocks do you think would go best with the Intrax springs? Intrax drops 1.75". I was thinking about going with tokico but is there something better??
Re: Tokico Struts
protege, since this is a suspension forum i have a question about your autox setup. do you run negative camber? if so, how many degrees?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: Tokico Struts
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by southern mx:<BR><STRONG>What shocks do you think would go best with the Intrax springs? Intrax drops 1.75". I was thinking about going with tokico but is there something better??</STRONG><HR></BLOCKQUOTE><P>Id say the Mazdaspeeds. The tockicos will be ok, but their warranty is void after 1.5" of lowering, and it could be a bit bouncier than with the Mazdaspeeds, but you will have saved yourself like 300 bucks. Its up to you, but i would, if i had the money, get the mazdaspeeds.
-93 MR2
#129 E-stock
#129 E-stock
Re: Tokico Struts
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cre8v mx3:<BR><STRONG>protege, since this is a suspension forum i have a question about your autox setup. do you run negative camber? if so, how many degrees?</STRONG><HR></BLOCKQUOTE><P>Actually, on my car, after lowering, the most negitive camber the shop could get was zero all the way around, which is crappy. Ill be buying cusco camber plates within the next 2 weeks, and then ill start with 1.5 degrees negitive and expiriment around a little till i find what i like.
-93 MR2
#129 E-stock
#129 E-stock
