I just found out something cool about the bpt.
- Franko
I was trying to fit the oil pressure sender unit on the back of my bpt when I realized that the engine has a built in oil cooler on it. Right under the oil filter, the oil is cooled by the radiator fluid before it goes into the heater core... Thats pretty awesome. I love my bpt, so full of suprises.
Re: I just found out something cool about the bpt.
This isn't just BPTs, my Escort BP came with this kind of oil cooler. If I stick with my high hp plans, I'll be taking a little load off the coolant system and using an aftermarket oil cooler.
- Franko
Cool.. Its a very good idea.. I was going to get a oil cooler but now mabey I will hold off for a while.
So Frank, you decided on an electrical gauge? What sort did you get and where you going to mount it?
the b6t has an oil cooler too
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- Franko
I got the same as my other ones. An autometer ultra-lite. At the same time I was ordering it off ebay I was ordering a gaugepod off gaugepods.com. It is going to be the full piece and holds 3 gauges instead of 2. =) I cant wait, it is going to look awesome!
Umm also, of anyone knows what size fitting goes into where the oil pressure switch is I would greatly appreciate it. I have a 1/8 th fitting now and it dosent seem to want to go in. What size are the threads on the stock sensor?
- papa roached
the threads are pipe threads, any brass fitting should fit as long as its the right size
- Franko
Yeah well I did get one that looked like the right size but it isnt. Its a tiny bit too big.
Sorry I can't help on the size - mine came with a selection of fittings (3 maybe?), one was the right one - just lucky I guess.
