What do i need to turbo my 1993 1.6 MX3?
List all items.
1.6 Turbo
- BuGS
Re: 1.6 Turbo
Check out racingmazda.com there is a list in there turbo kit that has all of a good ground basic setup.
Re: 1.6 Turbo
There are a few post regarding this subject and most of them point to www.racingmazda.com.
Sure that is all fine and dandy, but I am trying to figure out where to get a turbo exhaust manifold for the 1.6.
I am pretty sure I can build a down pipe and the intake.
- atlantamx3
Re: 1.6 Turbo
Look no further than a Mercury Capri or other B6T equiped car.
The exhaust manifold bolts right up to your car.
You can also find them at corksport.com
Re: 1.6 Turbo
Thanks.
projectmx
Re: 1.6 Turbo
the turbo manifold doesn't bolt up to your car... the 323 turbo mani bolts up to the dohc engine not the sohc engine
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
Re: 1.6 Turbo
Ok.......Then what turbo manifold will bolt up to the SOHC?
I have done the search and can not find the answer to my question.
projectmx
Re: 1.6 Turbo
as far as i've seen from posts in here the only one for you is the one from racingmazda.com
ProjectMx
Cardomain
Cardomain
Re: 1.6 Turbo
I found another place to buy a manifold for the SOHC. You have to be handy with a chop saw and welding.
JGS Precision Turbo
JGS Precision Turbo
