EGT stuff (need advice...)
Posted: September 20th, 2004, 11:09 pm
Hello all...
I recently put in some Webcam Cams and am retuning the S-AFC accordingly and was wondering if my EGT numbers are OK. BTW: this is on a B6T @ 13psi with the EGT probe mounted in the downpipe about 6 inches from the exhaust housing of the turbine.
cruising around town i get 850 (a/f gauge bouncing back and forth)
on the high way i get 1050-1100(depending on hills etc...)(a/f gauge bouncing back and forth)
and WOT at the top end of 4th i hit like 1350 (a/f gauge 2 bars green)
from what ive read the highway cruising and WOT appear to be lean but if i richen it up to get the high way temps down, normal driving it runs really rich. the plugs aren't white or anything. in fact they look pretty much the same as when i put them in a month ago just a little more golden.
are these temps ok?
thanx in advance for any help...
are these temps ok?
