best engine now?
ClutchedMX
best engine now?
Post by ClutchedMX »
KLDE w/e the new mods? I dont know i cant really decide if that does it or not.
wont the same mods fit on a ZE though so if you spend more youll be doing more HP as well?
papa roached
Re: best engine now?
Post by papa roached »
the KL-ZE is just hte hot rodded version of the KL-DE, all mods will swap over and you get 40 more HP
