Help with FMU's
Nomad_69er
Help with FMU's
Post by Nomad_69er »
I was wondering if someone can direct me to a stand alone fuel management system. I plan to run a 323 GTX manifold with a VJ14 turbo on a 95 1.6 DOHC. Does anyone out there just run with the stock ECU? I am working on a budget and I only want to run about 7-10 psi because I don't plan to do the internals. Thanks for the help.
ryanlindenberg
Re: Help with FMU's
Post by ryanlindenberg »
the most popular standalone seems to be the haltech...you can run your set-up using the stock ecu and a piggyback system though...there is alot of info on the board...type in haltech under the search thing and you will get alot of info.
CARDOMAIN WITH UPDATED PICS
Return to “Forced Induction”
