I'm not a big fan of modifying the chassis in any way, even something simple as drilling a hole in the firewall.
So, where have you guys run your lines? I am using a little plug by the passenger side right now but I need something closer to the drivers side.
Where to run boost gauge line through firewall?
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- BuGS
Re: Where to run boost gauge line through firewall?
If you look like right where the steering column is there is a little rubber stopper that you can pull out and go through there. It is on the drivers side. Thats where i ran all my sterio power and whatnot. I don't know what kind of can you have but this is on a 92 SOHC so ya... But there should be one.
