VJ turbos
papa roached
VJ turbos
Post by papa roached »
what one was the best for the 1.6L motors?
torpedan
Re: VJ turbos
Post by torpedan »
This is a question which is only answreable by you.. do you want something to spool up quickly or to take a while but have a raoring top end.. its all up to you..
-torp.
I don't own a Mazda.
papa roached
Re: VJ turbos
ok, give me a quick spool
torpedan
Re: VJ turbos
Post by torpedan »
Shot of NAAAWWWWSSSS...<p>
I would just take the turbo setup straight off of a Xr2.. they had a problem with turbo lag but the mx3s (dohc) 9:1 compression ratio will greatly reduce it and spool the turbo rather quickly (somthing in the size range of a t25-28 belive its a vj14 you can check the faq for which one it is off the b6t) the xr2 motor runs liekj a 7.6:1 compression ratio anyways so the mx3 motor should spool it quickly..
-torp.
torpedan
Re: VJ turbos
Post by torpedan »
Yeah and a link or two on where to get them
-torp.
Return to “Forced Induction”
