As some of you know my B6T went to poop; detonated in cyl.#2 and blew the rings in 1 and 4. Honing the block didn't fix the walls so she's going 20 over with the help of Wiseco 8.5:1 pistons. Head/throttle body/manifolds are getting ported and polished. Flywheel is getting shaved, I'm running larger I/C piping than my previous set-up and switching to a Pro LX ECU. Thinking about having the turbo manifold ceramic coated and getting the axles cryo treated but we will see.
Basically I'm hoping to be pushing close to or more than 200hp out of the box on a motor with practically 0 miles (after tear down and rebuild).
any thoughts/suggestions are appretiated...
the rebuild has begun...
- Shady469
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
