Intercooler sizes
- Custommx3
- Site Administrator
Intercooler sizes
I'm about to purchase an intercooler for my GS and I was wondering the dimensions of some of your intercoolers that you may have on your car. I dont want to get one too small, but I surely don't want one too large. Any help is appreciated.
maldo
Re: Intercooler sizes
Are you looking to buy brand new? If so, a good size is the Silvia core. GTR cores are good but you will want to watch the cfm ratings, when the core becomes 3" thick you start to see a greater pressure drop. 2.75" is a great depth but again this all depends on your goals. What turbo are you using?
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
- mrspanky79
measure the spot you want to put it in and go from there. You don't want anything thicker then 3" its a waste of space and $$ plus after 3" it has no extra cooling effect
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
- Custommx3
http://www.barrykclark.com/pix/GS/turbo.jpg<p>thats what Im using. It comes from a volvo 740 turbo.<p>600x300x76mm
450x300x76mm
790x300x76mm
770x300x76mm<p>Those are the sizes I can get.<p>[ August 13, 2003: Message edited by: Custommx3 ]</p>
450x300x76mm
790x300x76mm
- hotsiit
hey Barry, the intercooler i am using is 29 inches long, 7 inches in height, and 3 inches thick. It is spearco cores center welded together, that boostedmx had made. For my turbo system on the stock 4cyl sohc it is pretty much overkill
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
