E6K and speedo/tach
E6K and speedo/tach
I see that the speedo and tach get their input from the ECU which gets it's from sensors. With the E6K and the stock ECU gone, how do you run the speedo and tach? Does the E6K do it for you?
Re: E6K and speedo/tach
You use one of the aux lines from the E6k to run the tach. The haltech also has lines to run to a "road speed sensor" but I have a 93' with a cable drive so I cant really give you much info on that. If all else fails, run the the yard and pick up the stuff you need to convert to cable drive(cluster, cable, drive gear) and hook that up.
BPT SWAPED MX FOR SALE!!!
http://www.mx-3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=007118
http://members.cardomain.com/ricerocket666
AIM: l3acardiRon151
AIM: l3acardiRon151
- jaydog5678
By gone you mean you sold it or through it out?
You'll need the harness for the starter, alt, and main relays.<p>With the speedo gear, you can't use the BP speedogears nor the 1.8 v6's with the 94+ yr model. I have'nt verified yet, but the 2.5v6 gear out of the Mx-6, Probe, 626 may be possible.<p>The other possibility, like RiceR. said, run the gauge cluster, cable, and BP tranny gear.
take your tach wire and run it to the (-) side of the coil. also, the speedo isn't dependant upon the ecu. the haltech has a road speed input, but that's just for data logging.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
