Fuel pump?
Jowga28
Fuel pump?
Post by Jowga28 »
I know that with the BPT engine I need to upgrade my fuel pump for a 2gen rx-7 turbo one but I was wondering if this would work http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2413547728&category=33555 <p>or do I have to use this one?<p>http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2424540889&category=33555&rd=1<p>Thank you your help in advance.
Life passes you by so fast, keep up,drive a Mazda(ZOOM,ZOOM).
maldo
Re: Fuel pump?
Post by maldo »
Both will work.
Jowga28
Re: Fuel pump?
Post by Jowga28 »
Thanks man
mrspanky79
Re: Fuel pump?
Post by mrspanky79 »
http://www.autoperformanceengineering.com/<p>the FMP204 is what i used perfect fit didnt have to cut any wires and works perfect plus a real nice guy to deal with. And fast servise, two thums up from me. The only thing with the kit that didnt fit was the new tank seal, i guess the mx6 has a smaller opeaning.<p>[ July 23, 2003: Message edited by: mrspanky79 ]</p>
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
UnkleDuke
Re: Fuel pump?
Post by UnkleDuke »
Hey Mr Spanky...
Where is Keswick located from London or TO?
I'd like to check out your setup<p>Cheers
No Sig
mrspanky79
Re: Fuel pump?
north east of london north of TO im right at the bottom of lake simcoe.
99 vitara 4x4
philcosta
Re: Fuel pump?
Post by philcosta »
i did the BPT swap but i still have my old fuel pump<p> should i change it and whats the advantages
ryanlindenberg
Re: Fuel pump?
Post by ryanlindenberg »
yes you should upgrade your fuel pump, your old pump is probably running at full capacity. if you turn up the boost a little you will probably go lean and get detonation. detonation = bad
CARDOMAIN WITH UPDATED PICS
Return to “Forced Induction”
