BPT heads = junk
David Coleman
Re: BPT heads = junk
wow, thats horrible, couldn't you just grind it out?
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
maldo
That is exactly what I have been saying for the last year. Get a BP shortblock and use a NB head from the '99+ miata. Not only are the ports of a better design (ie. angle) but you also get a better valvetrain. My B6T wasn't much better, I had to hog that out quite a bit to get a good increase in flow.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
- jaydog5678
Yeah Dave, according to Mazda it offers better cylinder filling at low speeds and a higher velocity of incoming air. At higher airflow speeds, it's just a big restriction. It offers somewhat more torque in lower engine speeds through this design, but you can betchya I'll be switching once money permits. I think this design is one of reason's why the red limit was set lower than the n/a 1.8's (6200).
ProtegeSTS
while we're on this topic, here's the "famous" GT-R engine's intake port...<p>
-93 MR2
#129 E-stock
#129 E-stock
How much would a miata head cost?" and how much power would it add
Turbo 2.5l mx3
That will vary a lot pending what area you are in.. www.car-parts.com is a good place to check though.. altough you are lieky to be better off with a phonebook and a telephone doing it the old fashioned way.<p>
as for gains lets us know =]
-torp.
I don't own a Mazda.
maldo
$400 usd for a NB head with valvetrain is not bad, seems to be a going price at the JY.
Chris Malden
MX-3 RSR
MX-3 RSR
