I want to swap soon to the b6t
I've been reading up , and I;ve learned alot , but i'm wondering if anyone has any tips
or pictures.
any help would be great
thanks
I read up on the specs of both engines and I could not honestly see doing the swap over just a bolt-on turbo. I did notice that the rod might be longer on the B6T, but that was all I could see. A BPT swap may be the answer though.
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II My MX-3 Website
have you done the swap or done a custom set up?
and i thought that a bpt was harder to swap?
doesn't alot more stuff have to change than with the b6t?
i'm working more on cost..i've found a turbo 323 locally , and buddy wants 600cdn for the hole car
I just did the bolt-on. The BPT is harder, but it is a better option if your looking for HP. Consider it if your going to tear an engine out of your car.
Spend a lil more money and get the BPT, i think you would be happier in the long run. If you do the b6t and then you want more power i think you would want to kick yourself in the *** for getting it instead of the bpt
i thinking about swaping in a b6t into my 95 dohc i would add the turbo but the engine has almost 1000's miles on it.....i want to put on the b6e head b/c i dont want to have the throttle body stick out.....hood..........what are u running for a air/fuel computer
jason
