four cyl swap info
Guest
four cyl swap info
does anyone know if a 1999 or newer protege engine will be a dirct swap into a 93 SOHC..
dam2009
Re: four cyl swap info
99 protege is a DOHC (different mounts different harness, ECU etc.) it won't just fit in as a regular 93 SOHC
Guest
thanks for the quick reply..so why does a bgt and bpt fit in dirctly to the SOHC mx-3??<BR>thanks
maldo
The BPT, B6T, B6e, B6ZE are all B series motors. This is the motor that the mx-3 was designed around/for. The newer motors in the Protege are FSZE (I believe that is correct), making it much harder to squeeze into the MX-3 chassis.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
tell me what are all the b series engines out there and what the b6,b6t,bp,bpt and all others stand for and what car they come out of.
maldo
B6e - '86-'93 MX3,323 available in 8V or 16V configs<BR>B6ZE - '89-'96 M1 Miata, MX-3 (DOHC 16V)<BR>B6T - '87-'89 323 GT/GTX, '90-94 Capri<BR>BP - '90-'98(?) Pro LX<BR>BPT - '90-94 323 GTX/GTR (jspec only)
Chris Malden
MX-3 RSR
MX-3 RSR
qik_30x
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by maldo:<BR><STRONG>B6e - '86-'93 MX3,323 available in 8V or 16V configs<BR>B6ZE - '89-'96 M1 Miata, MX-3 (DOHC 16V)<BR>B6T - '87-'89 323 GT/GTX, '90-94 Capri<BR>BP - '90-'98(?) Pro LX<BR>BPT - '90-94 323 GTX/GTR (jspec only)</STRONG><HR></BLOCKQUOTE><P>actually the GTR came out with a BPD.<P>steve
BPD powered 4wd tx3 turbo laser.
- neverenuff
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by maldo:<BR><STRONG>B6e - '86-'93 MX3,323 available in 8V or 16V configs<BR>B6ZE - '89-'96 M1 Miata, MX-3 (DOHC 16V)<BR>B6T - '87-'89 323 GT/GTX, '90-94 Capri<BR>BP - '90-'98(?) Pro LX<BR>BPT - '90-94 323 GTX/GTR (jspec only)</STRONG><HR></BLOCKQUOTE><P>Now out of all these how many of them will you have to cut a hole in the hood for.I know you have to do it for the bpt but don't know about the others.Also what is the power rating on these motors?
OsoSlo z28
the b6t is the only one you have to cut a hole for.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
WHAT TURBOED ENGINE CAN I BUY AND JUST BOLT IN WITHOUT CHANGING EVERYTHING OUT FOR A 1.6 SOHC
