Turbo for dohc 1.6
Stevech_2001
Turbo for dohc 1.6
Post by Stevech_2001 »
I got a line on a turbo from a dodge daytona and was wondering what manifold to use and everything else to make a reliable low boost set up ie. fuel system, ignition etc. any help is appreciated
Steve
boostedmx
Re: Turbo for dohc 1.6
Post by boostedmx »
for a low boost system i would get yourself a b6t turbo manifold. intercooler from an eclipse or talon. as for fuel i would put an adjustable fuel pressure regulator on it for a little more fuel. maybe some injectors from a miata? depends on how much and how deep
Shady469
Post by Shady469 »
will that manifold (b6t) work on the SOHC?<BR>And boosted : When u hooked up your nitrous which TPS wire did u use?
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
boostedmx
Post by boostedmx »
the b6t manifold will not work on the sohc. i have a micro switch installed on my throttle body to open at wot. very easy to do and cheap. did you test the wires for power yet? if not turn the key on but not running, move throttle back and forth -probe all wires on tps see which one varies with your movements. during the test have the multimeter grounded well- probing with pos. lead. i prefer the micro switch
justin h
Post by justin h »
From what I heard from a miata guy, the manifold from a turbo Capri might work.
boostedmx
Post by boostedmx »
thats because it is a b6t.
monty73741
Post by monty73741 »
i have heard the dohc fits on the sohc but couple of the bolts dont bolt up<BR>this is probally gonna be my set up<BR>323 turbo manifold<BR>IHI turbo<BR>starion front mount intercooler<BR>some type of air/fuel computer<BR>rx7 fuel pump<BR>turbo timer<BR>electronic fuel pressure regulator<BR>probbaly protoge injectors<BR>jason
Jason Danaher
Please Help Support MX-3.com
Return to “Forced Induction”
