1.8 Turbo
1.8 Turbo
If I decide to turbo my little v6.... do I have to buy a new turbo from greddy or HKS or can I get one off a wrecked turbocharged car or something? If the latter is possible... what kind of vehicle would have a turbo that might be easy to fit onto my MX?<BR>Im not looking to make my car a dyno monster, just looking to make an extra 50-70 horsepower... .and no I dont want to do an engine swap I have my reasons... thanks in advance!
Re: 1.8 Turbo
you could get a used turbo off ebay?? the best turbo for your setup and goals would be either a used eclipse turbo or a common t3 turbo. personally i would go with the t3 because you can find weld on flanges for a custom header design and rebuild kits are dirt cheap and plentiful.
- mitmaks
Re: 1.8 Turbo
what else would i need to put in turbo/supercharger from eclipse into 1.8L V6
Re: 1.8 Turbo
turbo manifold and plumbing, relocate the battery. If you plan on running more than 5PSI, bottom end work to your block. Good luck
Shaun Newman
Re: 1.8 Turbo
how many HP do you get per lbs of boost you run?<P>also, if I get a turbo from an eclipse, and all the plumbing,manifolds that come with it etc.. how much work am I looking at to get it to bolt onto my 1.8L? I have all the equipment I need in my garage, I just dont want to spend two weeks fiddling with it to make it work<p>[ February 24, 2002: Message edited by: John Rykes ]
Re: 1.8 Turbo
any turbo kit will take a lot of fabrication, welding, and patience. nothing is going to fall in place. if you have the tools to make it happen it still will take some time to finish, maybe a couple weeks if not more. it is alot of hard work because everything has to be made for it. i would expect around 200hp to be safe. the engine will handle it just fine. it doesnt stop there though-- fuel and ignition have to be upgraded along with the exhaust system. like i said before though i would go with the t3 garett turbo
Re: 1.8 Turbo
you will need to: fabricate a manifold basically from scratch; hook up the oil lines from your oil pan to the turbo; run piping to and from a front-mount intercooler; fabricate a pipe from the turbo to the rest of the exhaust; relacate battery to rear (just to make more space). plus all the fitting and testing and reworking of things under the engine bay to make it all fit. a garrett T3 would be a good choice for a turbo, and look around on ebay for an intercooler that would fit. 2 weeks would be pretty quick for a first-time turbo install unless you know EXACTLY how you're going to do everything. do yourself a favor and buy a copy of Croky Bell's Maximum Boost--its the bible on turbocharging. good luck!
Dude.
