turbo ques
Guest
turbo ques
Hey sup <P>If i decide to keep my factory 1.6L sohc and i rebuild it is it as good as new? If i rebuild it whats the max boost i can run..is a turbo worth it.. good gains? Also as a daily driver can this engine hack it? tranny?<P>cheers
boostedmx
Re: turbo ques
as a daily driver i wouldnt exceed 9 psi of boost. the tranny and engine internals will handle that easily. the clutch may need to be upgraded since it is a weak unit from the factory. it is definately worth it in my opinion. with more tuning and mods better gains are possible in the future.
ProtegeSTS
Re: turbo ques
if you rebuild it right, and put good money into electronics and tuning, then you could run daily at ~15 lbs of boost depending on turbo size, which would make one hellava fast car, but its going to cost money.<P>The tranny will be the weak link, but if youre nice to it, it should last a while.
-93 MR2
#129 E-stock
#129 E-stock
Re: turbo ques
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ProtegeSTS:<BR><STRONG>if you rebuild it right, and put good money into electronics and tuning, then you could run daily at ~15 lbs of boost depending on turbo size, which would make one hellava fast car, but its going to cost money.<P>The tranny will be the weak link, but if youre nice to it, it should last a while.</STRONG><HR></BLOCKQUOTE><P>If you get an electronic boost controller, wouldn't you be able to run at 9PSI and then change it to 15PSI when needed?
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
ProtegeSTS
Re: turbo ques
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by VizualXTC:<BR><STRONG><P>If you get an electronic boost controller, wouldn't you be able to run at 9PSI and then change it to 15PSI when needed?</STRONG><HR></BLOCKQUOTE><P>Well yeah, but what fun is that?<P>
-93 MR2
#129 E-stock
#129 E-stock
Re: turbo ques
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ProtegeSTS:<BR><STRONG><P>Well yeah, but what fun is that?<P>
</STRONG><HR></BLOCKQUOTE><P>I don't know much about the Boost Controllers. Can you change boost levels from inside the car, say at a red light? If so, wouldn't that be the best thing on the engine? run 5-9PSI, then go to 12+PSI when a nice new red prelude pulls up beside you?
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
OsoSlo z28
Re: turbo ques
if you're boost cont. is capable, you can change boost settings while driving
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
