question on Super AFC and ecu
cjthor
Post by cjthor »
I am trying to decide what ecu to go with here... As most of you know I am transplanting a b6t into my dohc four. I am going to get the apexi super afc..Should I stick with the stock ecu or go with the protege? I know the protege gives you a better fuel curve but isnt that what the afc is for? Also what about the MAF? Should I still change it to the 87 rx7 if I use the afc? I just would rather save the money if I can. Thanks!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
maldo
Re: question on Super AFC and ecu
Post by maldo »
The choice on ecu is up to you. Remember that the S-AFC only modifies from the stock ecu signal, in some ways then the LX ecu is better.<P>You will need the RX-7 MAF. The MX-3 one is too small to attach to the Jpipe.
cjthor
Post by cjthor »
Is the only reason you change to the rx maf fitment? I am pretty sure I can get it to fit. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by maldo:<BR><STRONG>The choice on ecu is up to you. Remember that the S-AFC only modifies from the stock ecu signal, in some ways then the LX ecu is better.<P>You will need the RX-7 MAF. The MX-3 one is too small to attach to the Jpipe.</STRONG><HR></BLOCKQUOTE>
Jarid Perry
Ryencool
Post by Ryencool »
So sniper, would it be best in my situation to use the rx7 MAF or my stock MAF? I have a 92 4cyl, so its the sohc like yours..
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
OsoSlo z28
Post by OsoSlo z28 »
cjthor, i don't know what all is needed for the b6t swap but you might want to call derrick. for one thing, the pro lx ecu won't plug in for you. i found this out yesterday cause i have a dohc also. also, i'm not sure if the rx7 tb will clip into your harness. how many wires to you have going to your tps(sensor on tb). having the dohc creates issues. you have a crank angle sensor...the b6t and bpt do not. you have to have a bracket made so you can use yours. that's another reason you need your ecu and not the pro lx(they don't have a crank sensor)but my advice...call derrick
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
cjthor
Post by cjthor »
Well I got lucky today. We got a 93 RS in trade at my dealership. Boy that engine looks wierd... SOHC. The TPS looks different than the one on my DOHC. Alot of the wiring looks different as well. Does anyone know of somebody that has done the b6t to DOHC swap? I am getting soooo many conflicting reports on parts to use. I dont need the rx7 MAF or the protege ecu. Any answers would be great.
Jarid Perry
OsoSlo z28
seriously, the man to call is derrick at CS. it seems that everyone on this board has a sohc that did the swap. the pro ecu won't plug in. i'm not sure about the rx7 maf...but it might
"MR." Ashley Fowler
cardomain pics
Return to “Forced Induction”
