The door to my gastank hasn't been closing properly (I think someone messed with it), I now see that it's kinda cracked at the hinge. The metal is snapped. Kinda like when you bend a can back and forth til it breaks.
Anyways, any ideas to replace it? I don't think it's really fixable, or even worth the effort. Any aftermarket options? Any ideas what an OEM replacement would cost?
Thanks in advance ...
Gas Tank Door ....
Acamori
Re: Gas Tank Door ....
there's a company that can make you a cf replacement if you send them the original, i think it was like $60 for that though. if you can, you might think about checking out junkyards usaually that area of a car is less likely to be messed up it seems.
