clear headlight lens replacement
Posted: March 22nd, 2004, 2:25 am
by ruthless_mx3
for us poor/cheap people that can't afford projectors, someone should make just a replacement lens thats clear. The insides of the headlight housing isn't too bad looking, except for the metal bracket around the bulb.
If this actually does exist how much are they and who sells them? I don't mean the headlight covers either.
thanks
Re: clear headlight lens replacement
Posted: March 22nd, 2004, 10:28 am
by Custommx3
well, as far as a r eplacement lens, I know of none. IF you want to make your lenses clear again, read the appearance FAQ.
Posted: March 22nd, 2004, 11:08 am
by ruthless_mx3
I mean clear like clear without those lines that the factory lenses have
Posted: March 22nd, 2004, 12:06 pm
by monty73741
either way they will be expensive
Posted: March 22nd, 2004, 4:02 pm
by curtklze
if you remove those "lines" your lights wont light up the road properly and you wont be able to see much at night, you will also blind oncomming trafic.
Posted: March 22nd, 2004, 7:10 pm
by Tyler17rose
I think hes talking about sanding off all the ridges and lines so he can mount a projector inside the headlight. Without removing those nasty ridges and lines the projector beam will be terrible. The thing is, and i'm sure a couple people on this board already know this. (I know Eugene knows.) That sanding all those lines off is a huge job, and a big pain in the *** . And a aftermarket clean lens would be awsome.
Posted: March 28th, 2004, 7:01 pm
by millionflame
I think he means just having a clear lense without projectors behind it, which would be horrible just as Curt pointed out.
Posted: March 30th, 2004, 12:50 am
by David Witherow
you need those lines for proper light dispersment.....
