clear headlight lens replacement
ruthless_mx3
Post by ruthless_mx3 »
for us poor/cheap people that can't afford projectors, someone should make just a replacement lens thats clear. The insides of the headlight housing isn't too bad looking, except for the metal bracket around the bulb.
If this actually does exist how much are they and who sells them? I don't mean the headlight covers either.
thanks
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4 :(
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend ;)
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
Custommx3
Site Administrator
Re: clear headlight lens replacement
Post by Custommx3 »
well, as far as a r eplacement lens, I know of none. IF you want to make your lenses clear again, read the appearance FAQ.
ruthless_mx3
I mean clear like clear without those lines that the factory lenses have
monty73741
Post by monty73741 »
either way they will be expensive
Jason Danaher
Please Help Support MX-3.com
curtklze
Post by curtklze »
if you remove those "lines" your lights wont light up the road properly and you wont be able to see much at night, you will also blind oncomming trafic.
Yes, I AM a bastard
Tyler17rose
Post by Tyler17rose »
I think hes talking about sanding off all the ridges and lines so he can mount a projector inside the headlight. Without removing those nasty ridges and lines the projector beam will be terrible. The thing is, and i'm sure a couple people on this board already know this. (I know Eugene knows.) That sanding all those lines off is a huge job, and a big pain in the *** . And a aftermarket clean lens would be awsome. :shrug:
Mods:
millionflame
Post by millionflame »
I think he means just having a clear lense without projectors behind it, which would be horrible just as Curt pointed out.
~ Millionflame (94 GS 120K)
David Witherow
Post by David Witherow »
you need those lines for proper light dispersment.....
Return to “Appearance”
