Shaved Antenna
Posted: November 10th, 2003, 12:10 pm
by Johns93GS
If I shave my antenna, do you think the hole is small enough to fiberglass over?
Or is it so big that I need to weld a piece over it?
Re: Shaved Antenna
Posted: November 10th, 2003, 7:30 pm
by kuruption1983
dont be cheap bro. :p
nicely weld a piece of metal and smooth it nicely, my friend fiberglassed it and it was nice for the first 8 months, there after cut lines started to show.
Re: Shaved Antenna
Posted: November 10th, 2003, 7:44 pm
by Damien
I disagree with kuruption, mine was filled with fiberglass/bondo.
It still looks 100% mint.
The hole really isnt that big.
Re: Shaved Antenna
Posted: November 11th, 2003, 3:02 am
by EZ_4_FUN
I disagree with Damien. Mine was filled and has cracked! With the change in temp, its only a matter of time until the expansion/contraction of that crap gives way. You'll regret not spending the extra few bucks!! Especially if you get a custom 3 stage paint job as I did.
Re: Shaved Antenna
Posted: November 11th, 2003, 4:05 am
by streetconcepts
The best way to do that is to take a small piece of metal and epoxy it in place with metal bonding adhesive from fusor.
Fusor panel bonding adhesives (metal to metal)
Once dry drill several small holes in the new piece of metal and then skim coat with duraglass fiberglass based filler. The holes allow the bondo to go through and really grab. After the duraglass is sanded skim coat witha glazing filler and prep for primer/paint
Re: Shaved Antenna
Posted: November 11th, 2003, 11:47 am
by Spydie
my idea would be to fill the hole with JB Weld or Permatex Cold Weld....then grind in smooth. No welding and will not crack or distort with temp. changes.
Re: Shaved Antenna
Posted: November 11th, 2003, 9:56 pm
by Johns93GS
Thanks guys - im gonna be painting the car soon, so i'll keep you all posted
Re: Shaved Antenna
Posted: November 14th, 2003, 9:35 pm
by Silver_Wraith
This may be a little off topic but what do you use for and antenna when you shave your external what so you use for radio reception?
