Shaved Antenna
Johns93GS
Shaved Antenna
Post by Johns93GS »
If I shave my antenna, do you think the hole is small enough to fiberglass over?
Or is it so big that I need to weld a piece over it?
john kilfoyle .:. mx-3 fanatic
http://www.cardomain.com/id/johnmx3
kuruption1983
Re: Shaved Antenna
Post by kuruption1983 »
dont be cheap bro. :p
nicely weld a piece of metal and smooth it nicely, my friend fiberglassed it and it was nice for the first 8 months, there after cut lines started to show. :shrug:
Damien
Re: Shaved Antenna
Post by Damien »
I disagree with kuruption, mine was filled with fiberglass/bondo.
It still looks 100% mint.
The hole really isnt that big.
2004 Nissan Xterra - Daily Driver
2003.5 Mazdaspeed Protege - Sold
1994 MX-3 RS - Selling
Searching for a new performance car to buy, cant decide.
http://www.sounddomain.com/id/omenmx3
EZ_4_FUN
Re: Shaved Antenna
Post by EZ_4_FUN »
I disagree with Damien. Mine was filled and has cracked! With the change in temp, its only a matter of time until the expansion/contraction of that crap gives way. You'll regret not spending the extra few bucks!! Especially if you get a custom 3 stage paint job as I did. :sadwavey:
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
streetconcepts
Re: Shaved Antenna
Post by streetconcepts »
The best way to do that is to take a small piece of metal and epoxy it in place with metal bonding adhesive from fusor.
Fusor panel bonding adhesives (metal to metal)
Once dry drill several small holes in the new piece of metal and then skim coat with duraglass fiberglass based filler. The holes allow the bondo to go through and really grab. After the duraglass is sanded skim coat witha glazing filler and prep for primer/paint
Craig Flango
Body Kit Development Specialists
onlinesales@krazykustomz.com
Drift - EVO 5 - Blitz - BC2 - KMAX
Spydie
Re: Shaved Antenna
Post by Spydie »
my idea would be to fill the hole with JB Weld or Permatex Cold Weld....then grind in smooth. No welding and will not crack or distort with temp. changes.
Johns93GS
Re: Shaved Antenna
Post by Johns93GS »
Thanks guys - im gonna be painting the car soon, so i'll keep you all posted
Silver_Wraith
Re: Shaved Antenna
Post by Silver_Wraith »
This may be a little off topic but what do you use for and antenna when you shave your external what so you use for radio reception?
Wha-hoooo!!!! its finally in pics to come soon. http://www.cardomain.com/memberpage/540890
Return to “Appearance”
