Anyone Who has installed Fog lamps
what colour is the low beam wire <BR>thanks
Re: Anyone Who has installed Fog lamps
Just hook it up the main power to the batterie from the relay and then run the other wire to the switch and then the other side of the switch to the parking light circuit ro activate the relay for the fogs...this wire is red/black and will be in the bottom part of the fuse box..do not tap into the fuse box itself though because they are usually not designed to take higher currents during activation of the switch..<P>good luck<BR>Killermx3<BR>Certified Mobile Install tech<BR>MECP First class certified
