Fiber glass or Urethane???
letsroll
Post by letsroll »
I want to buy a body kit for my car and I want to know what is the best material between fiber glass and urthane. What are the pros and the cons of each ones?<P>Thanks in advance,<P>Eric :cool:
-=deathtrap-mx3=-
Re: Fiber glass or Urethane???
Post by -=deathtrap-mx3=- »
urethane kits are stronger i think. fiberglass kits usually need molding for an exact kit and flex more.<BR>hope this is right and that it helps. go urethane if you have a choice, but fiber is fine.
Looking for a 94+GS for KL-ZE fun :)
02 Protege DX Retired
93 MX-3 RS Gone But Not Forgotten
letsroll
Post by letsroll »
Yeah but do fiber glass is strong enough to resist a "bump" on the road or is it just for show rooms?
finchuck
Post by finchuck »
don't quote me but i believe that urethane is more flexable. it's much better than fiberglass, it's how a lot of stock parts come. fiber glass is made using two processes, one is handlaying and i think the other is called choppergun. if you are going for fiberglass, handlain is better because it doesn't have the "ripple" look in it. I bought the Spoilers Etc. spoiler a while back which had small ripples all the way down the damn thing. fiberglass will crack easier if it hits the ground. i've seen some people's fiberglass body kits shatter.
<A HREF="http://www.finchuck.com" TARGET=_blank>Finchuck Online</A>
-=deathtrap-mx3=-
thanks for clearing it up :D
david103
Post by david103 »
urethane is more durable and reparable, but cannot be added on to (hood scoops, etc). fiberglass is less durable, but just as reparable and can be added on to while being much cheaper. good fiberglass is probably your best bet. i don't there are any kits available in urethane for the unloved mx3.<P>dave
letsroll
Post by letsroll »
Does anyone here have a fiber glass body kit? and if so, did you have problems with it?
DVH
Post by DVH »
i have a fiber glass one (FX)....no probs yet,,knock on wood! lol! i 've drove in snow and ice and that sh*t too! its still holdin up good! u just got to be careful when driving! later :cool:
Derek Van Horne MX-3.com Member # 33
94 MX-3 Silver Stone Metallic CAR is SOLD
Car Domain Web page MX-3
Car Domain Web page SRT-4
finchuck
Post by finchuck »
i believe a good body shop can reinforce the body kits to make them more durable. i don't know what this process entails, but a buddy of mine that has a kit on his eclipse says they "reinforced the body kit"
powerman_5000
Post by powerman_5000 »
Maybe this will help some with your question. There are two types of fiberglass body kits: Sprayed fiberglass and Handlaid fiberglass. The body kits that are made using the spraying technique is mostly likely to be made poorly because you really can't control the amount being sprayed and certain spots on the kit will be weaker and more likely to break easier. Now the handlaid fiber glass is a lot better than the sprayed because the amount of fiberglass and the other mixture used with the fiber glass is controlled and all parts are the same strength, but another thing is that fiberglass always has a chance of cracking and not easy to repair. Now on to urethane. Urethane is a lot stronger and easily repaired. But the downfall of Urethane kits is the price. The urethane kits will cost a lot more than the fiberglass kits and is not as mass produced as fiberglass kits. All this infromation came from Sport Compact Car Magazine( Thanks to them for the great info). Can't remember what issue, but once I search my stack of magazines I'll tell you and you can read the article yourself if you like.
Return to “Appearance”
