Polishing headlights
Brainless
Post by Brainless »
I had my right headlight replaced by a used one because of a small crash. The problem is...it's all scratched (not that bad) and the guy at Canadian tire told me nothing could do the job. A saw a few post before about products that could possibly help.<P>Where can I get those??? :confused: <P>thanx!
Jonathan Michaud
93 Red RS
killerpickle
Re: Polishing headlights
Post by killerpickle »
you know, I've been asking the same thing...all I need is some kind of a weblink thats sells them...I dont know where a pep boys is, we have partsource but they didn't have it...I did buy some plastic cleaner/polish from home hardware...and it worked okay on the outside, but there was tonnes of stuff on the inside...so one day, I plan to take the light out of its mount and fill it with the solution and water...and soak it overnight...that should get rid of it...
Tom Alexander
Return to “Appearance”
