help please
ratkon
help please
Post by ratkon »
I have a 94 GS,It starts and idle's no prob,but when i give it gas it bogg's out.Anyone have a clue whats wrong.Thanks. :pimp:
DavidOS
Re: help please
Post by DavidOS »
hmm either vaccum or could be bad fuel delivery.
mazdubber
Re: help please
Post by mazdubber »
could be a distributer starting to go.
92 GS
'Stock'... :twisted:
bmwm3guy
Re: help please
Post by bmwm3guy »
did you check for any codes from your ECU?
ratkon
Re: help please
Post by ratkon »
Not yet,played with hose's and wire's.Now car run's fine.Something must be loose somewhere.
ratkon
Post by ratkon »
I checked code's and got 23, O2 sensor.I read the post about O2 sensors,and from what I understood from it the car would still run ok.I thought it was running ok after i screwed around with the hoses and wires,but that was wishfull thinkin.
