WINDOWS FOGGING UP!!
alright guys, im not sure if this is a ME problem or a general mx3 problem..
when its cold outside or raining or damp etc the windows always fog up... which is normal if you dont have the heat on... but if i wake up on a rainy morning and start the car, blast the heat and rear defog, the windows are clear when i get in, after 5 or 10 minutes of driving the side windows are always fogged up.. except for a small window int he fog cause the side vents help a little... the rear window stays unfogged when the rear defog is on (the light in the button doesnt work which is annoying) and the top 3 wires dont work, (any help on how to fix those woudl be nice too)... but basically, with the heat on full blast, all on defog windows setting, should they realyl fog up so easily?? any suggestions?
Re: WINDOWS FOGGING UP!!
depending on the year of your car i would be very careful with that rear defog. you are only suppossed to leave it on for like 10 minues max or else it will burn out the relay. mine is toast.
Management is not responsible for lost or stolen virginities.
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
If you haven't tried already, use the fresh air setting, not recirculate. You'd be surprised how much humidity your breath can create.
yeah, tried that... it doesnt make any difference... the only thing i can do to stop it is keep my sunroof open a crack... but i cant be doin that in the winter, it will prolly be frozen shut, and i cant do it when its raining hard either..., also my car is a 1993...
I use windex auto on my glass, both inside and out. It has stopped it from fogging up nearly as much as it did.
You have quite likely got a very small leak in the heater matrix, so coolant is being added to the air. It only takes a small amount to fog things up.
You can buy a small bottle of conductive paint made specifically to repair breaks in the heating element on the rear window.
[Its not true about only running the rear window heater for 10 minutes. Mine has run for hours at a time and is fine]
I had the same problem with my rear defogger when i first bought my MX-3. Under the driver side dash above the brake pedal there should be a harness with a small black cube (relay) ...when you press your rear defogger button that black cube should make a small click sound. If it does not then most likely the relay is worn out. Its a standard size relay so you can get a replacement for less than $5.00 US at most auto parts stores
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
hgallegos915
My rear defoger turns itself on after 15 minutes of continous use I believe. As for the foggin..you may have dirty widnwos tru the inside and also maybe your vents are open. Also..is your heater working right? are the levers where they are supposed to be? Mi windows clear up quite nicely. I only use the rear defoger for when ice is there. After it melts away theres no fog.
-hec
- mitmaks
my gs has rear defog and it turns itself off as it defogs rear window, neat feauture, nice car for '93, theres no other car for price you can find that has as many feautures and looks as good
- Zoso124
The front defrost system stinks on the MX3. Quickest way to defrost the front is to put on outside air, heat on high and the trick is to turn on the A/C. This will put the driest air on the windshield, if you ever noticed when a car is on defrost the A/C compressor cycles every 30 seconds or so.
Mike Evans
Gone:
Gone:
Mine does the same thing could be my weather seals being all screwed up but i have seen it tho its eather fog up or be cooked..
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
As someone already mentioned, the trick is to run the A/C at the same time. hopefully yours is still working.
Andy P. 93 GS
Andy P. 93 GS
Gro Harlem
Turn the A/C on.....problem solved
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Gros right turn on the A/C and dont breath so hard
i just set my vents to fresh air and i've never has that problem, but on re-circulate, she fogs up really quick. If neither work, i would just hold my breath
