dead 92 mx-3
dead 92 mx-3
I had some trouble the other day getting my car to start. It would start but then I would have to rev it up quite a bit to keep it started and now it will not start at all...any thoughts, mabey the fuel pump?
1992 MX-3 GS in work.
2006 speed6, Wife say's i can't work on it.
2004 GSX-R 1000 Mat Mladin Replica
2006 toyota tacoma
1995 MX-6 in pieces almost ready for the junk yard, To much body damage.
2006 toyota tacoma
Re: dead 92 mx-3
If you had to rev it up to keep it running, I'd guess vacuum leak. Otherwise, not starting at all sounds like a bad distributor.
Re: dead 92 mx-3
Remove the big ribbed intake hose and flex it while inspecting closely for cracks, especially between the ribs. Might not be the cause but it fits your symptoms and is often overlooked. If you find any cracks, a temporary seal can be made w/duct tape til replaced. Your problem sounds like this type of unmetered air leak into the intake stream.
Re: dead 92 mx-3
Another way to check for leaks in the intake system (assuming you can get the car to start) is to have somebody rev the engine while spraying WD-40 around any joints or possible leak points. You'll see the mist getting sucked in and also hear a change in the engine.
Re: dead 92 mx-3
thank you all for your info, today I try these you all have said and see if it works. again thanx.
2006 toyota tacoma
2006 toyota tacoma
Re: dead 92 mx-3
Well I got it started but it sputters real bad till the upper r.p.m's. It idles fine but when i give it gas it sputters almost stalls then rev's up everytime. I just don't know...
2006 toyota tacoma
2006 toyota tacoma
