Anyone else's ECU go goofy sometimes?
About once a week, I'll start my car and the check engine light will be on and my car will run like it's in diagnostics. All I do is turn the car all the way off, and immediately back on, and it's fine again. WTF is that all about?
Re: Anyone else's ECU go goofy sometimes?
sounds like you have a short somewhere or a bad ecu
Sacramento Raceway, CA
92 Mx3 GS
New Time 13.82 at 101.75 2.205 60ft (RIP beast klze engine)
Updated mods now... KFZE, SS Autochrome Headers and a Sweet a-- 3' Electric Cutout after it, KFZE LSD trans, Millenia manifold, KL36 ecu, Blown motor mounts, custom CAI, Custom ground wire kit, 9mm Plug wires, 2 1/4 exhaust, (Hei and MSD external coil mod), all accessories.
92 Mx3 GS
- jumboplay
I've heard of this before. My friend's GS did the same thing. He went to the junkyard and pulled another GS ECU...never happened again. If it's free or close to it, it's worth a shot. But definitely check other things first...a short or a loose connector on a sensor or something.
Good luck!
BTW, what's the code that you get when it's on?
Good luck!
-Tom J, proud MX-3 pilot-
Get your entertainment upgraded at http://www.tommyv2.com
1996 MX-3 RS/GS hybrid, OBDII B6-ZE, painted Mazda crystal white, ZX-2+Eibach, Miglia Spyder 17"s, markerflash, black altezzas, insane fuel economy, too many other mods to list...
Nothin. I shut the car off to put the jumper in the diagnostics box, and the CEL is gone already.BTW, what's the code that you get when it's on? [/QB]
How can you test to see if your ECU is bad? Is there a way?
1993 Mazda Mx-3 GS-Sold ![Sad :(](./images/smilies/icon_sad.gif)
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
Swap in a "known good" ECU and see if the symptoms go away. Other than that - send it away to a specialist.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
damn...i was hoping it would be easier than that. Thanks
